Have you been stuck juggling versions of documents via email? Learn how Box can streamline the version control process
Notifications keep you connected to colleagues and let you monitor your content. Learn how to make them work for you!
Box has a ton of collaboration tools. Learn how you can use these to increase productivity in your day to day work with teammates and your entire organization.
When you need a document, chances are you want it as quickly as possible. Learn how you can use Box to work effectively with content, manage your content, and boost productivity!h
Do you wish you could have a custom folder structure for every task? Check out the Tag tool!
Want to have the Box tools you know and love everywhere you work? Check out Box Embed!
With Box, your institution has a solution that is easily adoptable by students, staff and faculty to share all the documents, presentations and content used every day in school. Learn how to set it up here!
Telecom companies use Box as a centralized content platform for every user, helping employees, contractors, and third-party vendors work more productively. Learn more!
From exploration to production activities, to managing the distribution of power across the grid – Box can help you gain and maintain a competitive edge.
With Box, you can collaborate easily with people inside and outside of your organization. Learn about the different levels of admin control to help you make the right choices for your user base!
Learn how using Box can benefit organizations covered under SOX and help you meet compliance obligations.
Every Box user is different, but managing them doesn’t have to be difficult. Learn about how to customize each user’s access to fit their role in your organization.
The combined Box and Chatter platform helps you communicate and socialize effectively around your content. Get started here!
Yes, you read that right! Box and SharePoint can coexist – this guide breaks down how to leverage these systems create a unified user experience.
Do you use Salesforce.com everyday? You’re in luck, the Box integration can boost your efficiency. Learn the details for set up and integrating it into your workflow.
